motion blur weirdness
  • motion blur weirdness
    I'm having an issue with regards to motion blur.
    The basic setup is as follows...
    I have a simple piece of hoop shaped geometry rotating 360 degrees around the Y axis over 1 frame.
    My motion blur settings are
    Duration (frames) 1
    Geometry samples 25
    The problem is that it renders with a dark line running along the Y axis. This shouldn't be happening and I'm out of ideas why this could be.. Hopefully someone here knows?
    Massive thanks.
    Joe
    hoop_motion_blur_v01.mb.zip
    This dark line is actually normal. Intuitively, the probability for the ring to be at any position is equal if you rotate on 360 deg. However, you render a different thing - the probability to hit the front surface of the ring. It's actually 2 times lower at the dead center, since the ring passes this position only one time. Here is a simple image:
    If you don't want this dark line, you must make the probability above also equal at all degrees. This is actually simple - make the material fully transparent (without turning on the "Multily color by opacity"). Here is a scene:
    mb.zip
    V-Ray/PhoenixFD for Maya developer
