vrayUserAttributes upper-case
  • vrayUserAttributes upper-case
    I'm using the latest vray nightly build for maya 2015, on win 7.
    It seems there's a problem with vrayUserAttribute and tags on file texture.
    For an object with a vrayUserAttribute on it that defines a texture version : 'skintype=1'.
    I've correctly set the file texture path to path/skin_<skintype>.jpg and it works.
    But if I create a vrayUserAttribute on the parent group and set it to 'ACTORS' it does not work anymore.
    Then changing 'ACTORS' to 'Actors' or 'actors' seems to be fine.
    Is there an upper-case bug with the vrayUserAttribute ?
    If so, could you do something to fix it or do I need to find a workaround ?
    Thanks,
    Max
    Seems to work fine here. What VRay and Maya versions are you using and on what OS? I might have missed something.
    Alex Yolov
    Product Manager
    V-Ray for Maya, Chaos Player
    www.chaos.com
      I don't remeber excatly wich nightly build we're using. It's Vray 30504 for Maya 2015 on Win 7 x64.
      Here is a scene that reproduce the problem : http://we.tl/qChnWxkVsQ
        Can you check what's the exact build number, you can get it from the Maya output window.
        Your scene doesn't work on my end, I can confirm that, but if I make a new scene everything works fine. I'm still trying to figure out exactly what's wrong.
        Alex Yolov
        Product Manager
        www.chaos.com
          Ok here is the vray version :
          [2015/Mar/25|14:45:19] V-Ray: V-Ray for Maya version 3.05.04, revision 25503 from Jan 28 2015, 02:41:47
          [2015/Mar/25|14:45:19] V-Ray: V-Ray core version is 3.05.07
            Do you get an error or warning when rendering, saying that "Bitmap file path/file.ext" failed to load?
            Alex Yolov
            Product Manager
            www.chaos.com
              Hmm, I just noticed that you have another user attributes attached to a group node higher in the hierarchy. This might have something to do with it.
              Alex Yolov
              Product Manager
              www.chaos.com
                Yes It is what I was trying to explain in the first place.
                If you change the case of the user attribute attached to this group node it would works
                  Yes, sorry that I missed that in the beginning. I think the attribute should have some value assigned to it, otherwise it won't work. You can give the group node attribute some value (ACTORS=0 or ACTORS=ACTORS).
                  Alex Yolov
                  Product Manager
                  www.chaos.com
                    VRay should actually skip only the attribute that's missing a value (on the group node) and still evaluate the one below. I'll make a note about this in our bug tracker, but until we fix it I'm afraid you'll either have to assign a value to the group attribute or use non-upper case name for it.
                    Alex Yolov
                    Product Manager
                    www.chaos.com
