Locators not visible in VP2.0
  • Locators not visible in VP2.0
    I've noticed for some time now I can't see various VRay nodes in Viewport 2.0 mode of Maya 2015. Is this a known issue ? (I suspect I've just messed up a setting somewhere.)
    Namely, blank scene, create VrayRectLight. No locator visible for manipulation. (works fine with any other Viewport mode)
    up to and including nightly: 30504_maya2015_x64_25699
    Is there any chance that you've switched the viewport to DirectX mode?
    V-Ray developer
      Ah yes. That was the case. Switched a while back, assuming it was preferrable for a none-quadro (in this case Titan-Z).
      Still not seeing light effects (although the actual locator is at least visible now). Thank you very much
        The lighting is supported only with VRay materials and when you turn on the texturing.
        V-Ray/PhoenixFD for Maya developer
