xgen issues
  • xgen issues
    hi
    I have a scene i can render fine in maya but in cmdline render maya batch it fail
    i start maya :
    set MAYA_RENDER_DESC_PATH=C:\BATCH\vrayMaya3.0\maya_ro ot\bin\rendererDesc
    set VRAY_FOR_MAYA2015_MAIN_x64=C:\BATCH\vrayMaya3.0\ma ya_vray
    set VRAY_FOR_MAYA2015_PLUGINS_x64=C:\BATCH\vrayMaya3.0 \maya_vray\vrayplugins
    set VRAY_AUTH_CLIENT_FILE_PATH=c:\Program Files\Common Files\ChaosGroup
    set PATH=%PATH%;C:\Batch\VrayMaya3.0\maya_root\bin
    set MAYA_PLUG_IN_PATH=C:\BATCH\vrayMaya3.0\maya_vray\p lug-ins
    set MAYA_SCRIPT_PATH=C:\BATCH\vrayMaya3.0\maya_vray\sc ripts
    set XBMLANGPATH=C:\BATCH\vrayMaya3.0\maya_vray\icons\% B
    set PYTHONPATH=C:\BATCH\vrayMaya3.0\maya_vray\scripts
    C:\MAYA2015\bin\Maya.exe
    -> set project -> load scene -> start render -> all ok
    but in cmdline render it fail !!
    c:\maya2015\bin\render.exe -r vray -proj "C:\Users\....\Desktop\xgen" -rd "C:\Users\....\Desktop\xgen\test.mb" -threads 32 -s 1 -e 1 -b 1 "C:\Users\.....\Desktop\xgen\scenes\test.mb"
    the render log say error
    [2015/Apr/13|16:20:03] V-Ray: Translating scene geometry for V-Ray
    [2015/Apr/13|16:20:03] V-Ray warning: Could not find alembic file with patches for palette "fur2" required for batch render!
    [2015/Apr/13|16:20:03] V-Ray: Total time translating scene for V-Ray 0h 0m 0.0s (0.0 s)
    I not have such an error in maya GUI render
    insteat I see in the log maya is loading the xgen.py of vray
    do i need to "set" a parameter to load xgen.py in batch ?!?
    __________________________________
    - moste powerfull Render farm in world -
    RebusFarm --> 1450 nodes ! --> 2.900 CPU !! --> 20.000 cores !!!
    just 2,9 to 1.2 cent per GHZ hour --> www.rebusfarm.net
    Did youy do this ? http://docs.chaosgroup.com/display/V...in+Maya+Batch#
    www.deex.info
      yes I did
      but I assume the matter is maya itself
      in SP6 i see a note the change log about xgen and batch
        Is there an .abc file in the folder with the scene? It should be named like this: <SCENE_NAME>__<COLLECTION_NAME>.abc
        In your case I think it should be this:
        "C:\Users\.....\Desktop\xgen\scenes\test__fur2.abc "
        If there isn't one I suppose the exporting of that alembic file with the patches for batch render has failed.
        Check the script console for errors while exporting the patches for batch render to .abc.
        Are there any spaces in the path to the scene? If so, I would suggest using a different path - XGen is not good with paths with spaces in them. Try saving the scene directly in C:/ or D:/
        Which version of Windows are you using? 7/8/8.1
        Which service pack of Maya 2015 are you using? SP6? I saw some batch related comments in their changelog too but we were not aware of any such batch-related issues with V-Ray.
        I could not reproduce this problem with SP5 and SP6 of Maya 2015.
        V-Ray for Maya developer
          I seem to be having a related problem. The patches seem to export, the file is in the correct place , i don't really get any error messages, but the hair remains static. No dynamics. No animation. When i import the abc file to a new scene it doesn't seem to have any moving elements to it. Should it look like the hair geometry? How can i check if it's worked or not?
          Do you have to select anything before doing file- export patches for batch render? I'm not exactly sure which node the 'patches' actually are...
            @Bertjenkins - The alembic file with the patches is just the source geo - all the objects on which xgen primitives are generated for the current description/collection. The hair is generated on-the-fly in batch using the alembic file and the .xgen file (the description).
            When exporting the patches have you exported them as animated for a time range?
              Yes. the movement starts at frame 80. It all plays fine and renders fine in the viewport and vfb. I've tried exporting the patches from frame 80 to 200 and from frame 0 to 200. Both don't work. As soon as you render the hair is stuck on frame 80 and doesn't move.
              maya 2016 ext 1 sp4 PC.
                Did you enable the "Animated" checkbox in the dialog for patch export?
                V-Ray/PhoenixFD for Maya developer
                  yes i did, I have followed the instructions exactly as per the vray and autodesk instructions
                    i thought it might be dr, so tried with and without dr and still doesn't work
                      If it's not confidential, it will be best to send this part of the scene to the support for more detailed investigation. You may also try rendering with Mental Ray to see if it's producing the expected result.
                        @Bertjenkins - Do you atleast get the expected animated result when rendering from within maya? no batch stuff... When rendering straight from maya that alembic file with exported patches is not even required.
                          I will try to do this when i get a chance. It will take quite a while. In the mean time is there anything i can check for? I'm assuming that there is something wrong with the xgen file then, not the abc file. The animation data is not exporting. Is there any other way to do it? Any workarounds? how about exporting a vrscene file? I really need this render
                            sorry missed this one. yes rendering within maya is fine. setting off a render from the vfb gives the required result
                            • #15
                              i have changed the nucleus start time to frame 80. could this be a factor?
