Hi all,
I think I've come across a bit of a bug with V-Ray 3.0 (running it in Maya 2015 SP6 Extension)...
I've got an interior scene that has got quite a lot of lights in it, comprised of 51 Vray Rect Lights that simulate day light and interior strip lights, and then 26 IES Lights that are used for spot lights.
I'm trying to split these lights out in to a few separate Light Select render elements so I can control them in post and I'm having some problems getting it to do it correctly.
I've got a 7 light select elements for the rectangle lights, and these render fine, but when I add another that just contains the IES lights, all of the light select elements render just black. The lights show fine in the RGB Color pass, but they won't show any of the light select elements.
In doing some playing around with it, this extra light select element seems to work if I only have 4 IES lights visible (and hide the rest), but if I add any more it just renders black on all light select elements.
Is this a bug? Am I doing something wrong? Have I exceeded the amount of lights or something?
It's also happening on a similar scene that a colleague is currently working on.
Need help asap if anyone knows the answer
Thanks!
Thanks!
