We are experiencing crashes (Linux only) when using the new Maya 2015 Extension 1 SP6 with versions of V-Ray 3 which used to work fine with Maya 2015 Extension 1 SP5. On Windows, it all works fine.
I'm having issues with figuring out whether this is a problem with V-Ray or Maya (I'm guessing Autodesk changed something which causes V-Ray to crash).
So to summarize;
- Original Maya scene was created with V-Ray 2.4 for Maya 2014 Extension SP1.
- When opening this scene in V-Ray 3 (stable) nightly build 25208 for Maya 2015 Extension 1 SP6 on Windows, it would render without issues in the VFB.
- When commandline rendering this scene in V-Ray 3 (stable) nightly build 25208 for Maya 2015 Extension 1 SP6 on Linux, it crashed.
- When commandline rendering this scene in V-Ray 3 (stable) nightly build 25208 for Maya 2015 Extension 1 SP5 on Linux, it rendered without issues.
Should I be contacting Autodesk about this?
Code:
Error: line 1: Unknown Maya file version: 2015ff05. Maya binary file parse error: : (6) corrupted file structure Warning: line 1: Errors have occurred while reading this scene that may result in data loss. File read in 0.024 seconds. Error: line 1: Error reading file. Error: line 1: Error reading file. Error: file: //192.168.0.225/Pipeline/bin/vray/builds/141107_vray_v3.00-b25208-stable-maya2015_linux64/maya_vray/scripts/vrayRegisterRenderer.mel line 62: Cannot find procedure "vrayDebug". Warning: file: //192.168.0.225/Pipeline/bin/vray/builds/141107_vray_v3.00-b25208-stable-maya2015_linux64/maya_vray/scripts/vrayRegisterRenderer.mel line 165: Unrecognized node type 'VRaySettingsNode'; preserving node information during this session. Error: file: /tmp/ASTMP4VEgj5.mel line 9: setAttr: No object matches name: vraySettings.width Error: file: /tmp/ASTMP4VEgj5.mel line 41: Scene //192.168.0.225/prod/proj12/maya/scenes/scene2.mb failed to render. // Maya exited with status 210
