UDIM render issue
  • UDIM render issue
    Hi there
    I have been experiencing a very strange VRay issue.
    Rendering an image as normal image sequence (image.1001.png) and then rendering the same image using <UDIM> (image.<UDIM>.png) the rendered image shifts very very slightly.
    I have attached a few screen shots to highlight the issue. These are renders of a plane with standard 0 to 1 UV coverage and a texture checkerboard applied via the 2 techniques mentioned above. The difference is very slight so may not be instantly noticeable so I included a difference render too.
    Normally a shift of this tiny magnitude wouldnt be an issue but I am working on a sprite crowd system that required very accurate use of UV space and UDIM tiles. When only viewing 0.1 x 0.1 of a UV space the difference is very noticeable.
    Please let me know if there is a work around or a planned fix
    Thanks
    Maybe try a different filtering method for the texture or even turn off filtering completely? I'll try to figure out what's wrong in any case.
      Hello, this should be fixed in the next nightly build.
      Radoslav
      Radoslav Platikanov | Chaos R&D
        Great, many thanks.
