vrayCreateProxy options + Maya 2016 crashing
  • vrayCreateProxy options + Maya 2016 crashing
    I'm trying to export an animated vrayProxy in Maya 2016 with V-Ray 3.05 nightly build 25823.
    First off, Maya freezes when scrubbing the timeline when viewing an animated vray proxy. It also freezes during vray proxy animation export. This may not be V-Ray related but other users get this in our facility as well.
    Since I've got a custom script which sets up the proxy, I need to perform the proxy export using the vrayCreateProxy MEL command. I'm having some difficulties getting the animation settings right. See below:
    In the vrayCreateProxy command, you choose to specify "Use playback range", "Use animation range" and "Specify range".
    I'm assuming that this refers to the -animType parameter of the MEL command and that they work like this:
    "Use playback range": vrayCreateProxy -animType 0
    "Use animation range": vrayCreateProxy -animType 1
    "Specify range": vrayCreateProxy -animType 2
    Also, I'm assuming that "Use animation range" detects the frames on which there are animation and exports only that range. But when using -animType 1, the whole timeline is exported. When checking the docs, it just says "the whole animation is exported"... so it's difficult to understand what the intended use is here. Also, when I try -animType 0, only the first 10 frames or so are exported at all times, regardless of what my render globals are like or how long my timeline is.
    So: if I want to export only the range where there is animation for the selected object (which I want to export to proxy), what -animType value should I be using?
    Best Regards,
    Fredrik
    "Use animation range" should export the Maya animation range vs. "use playback range" should get the Maya playback range. I'm afraid the proxy export will not scan the object for any keys/animation.
    We'll update the docs to make this a bit more clear.
    As for the crash - is there a way to try and make the same export with Maya 2015 for example? Or send us the file over so we could take a look. Also - does the drive you're saving to have enough free space?
    Alex Yolov
    Product Manager
    V-Ray for Maya, Chaos Player
    www.chaos.com
      A sort of related issue I just noticed when we're testing this is that when changing the motion blur duration(frames) to more frames than 1, the vray proxy doesn't render with "longer" motion blur as the object will if its not turned into a proxy.
      The motion blur looks correct if its set to 1, but seems to have no effect if changed. I tried this both having an animated alembic file and a vrmesh file, with velocity information. This is the case with one of the latest nightlies (a week old I think), and some of the older ones aswell.
      Am I doing something wrong? (Did I miss to change something in the proxy settings) Or is this indeed a bug?
      CG Artist - RnD and CG Supervision at Industriromantik
        The V-Ray proxy does not support moblur larger than 1 frame (bounding boxes will be wrong).
          Oh I see, I didnt realize that was a limitation. But makes sense.
          Thanks for clearing it out
            [ATTACH=CONFIG]24548[/ATTACH]
            Ah... I see now. Having used Maya for 10 years and I wasn't aware of the terminology "playback range" vs "animation range" - I've just been calling it "the timeline". Your image cleared things up. Many thanks for taking the time to make that.
            Yes, I can re-create and export in Maya 2015 without any crashes. The drive has several terabytes of free space. I'm getting the crash on another machine too, different nVidia based graphics cards (GeForce GTX 970, Quadro K5200). I'm attaching a scene file which will need a couple of external files: scene13.zip
            Just open it and set the assemblyDefinition node to view the vrmesh representation or the abc representation Then scrub the timeline quickly. Perhaps you will need to go back and forth a couple of times between the representations and scrub again. Here that will eventually crash Maya with a Windows window saying the following:
            Code:
            Problem signature:
              Problem Event Name:	APPCRASH
              Application Name:	maya.exe
              Application Version:	16.0.1312.0
              Application Timestamp:	54efcee1
              Fault Module Name:	StackHash_c1ff
              Fault Module Version:	6.1.7601.18869
              Fault Module Timestamp:	556366f2
              Exception Code:	c0000374
              Exception Offset:	00000000000bfc22
              OS Version:	6.1.7601.2.1.0.256.48
              Locale ID:	1053
              Additional Information 1:	c1ff
              Additional Information 2:	c1ff60389084812c4135c96e1c906b0d
              Additional Information 3:	e65a
              Additional Information 4:	e65a81f395ef7bfc4265c05cd65c5ac2
            Read our privacy statement online:
              http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409
            If the online privacy statement is not available, please read our privacy statement offline:
              C:\Windows\system32\en-US\erofflps.txt
            Best Regards,
            Fredrik
              Thank you very much for the scene. I've reproduce the crash and it seems to be VRay related.
                That is actually great news, as I was looking to start my own investigation on nVidia drivers and Maya 2016 incompatibility... but then I can move on to more important things!
                Best Regards,
                Fredrik
                  The crash/freeze should be fixed in the next nightly. The problem is that Maya 2016 tries to evaluate the graph in parallel, but VRayMesh nodes don't support this. It turned out we must manually tell Maya this.
                    Wow, that was fast. Excellent!
                    Best Regards,
                    Fredrik
