LC and IR path not adjustable on renderlayers
  • LC and IR path not adjustable on renderlayers
    It doesn't appear to be possible to set a render layer override for IR or LC filepaths.
    Is there any way around this? or do we need to set up different scenes to create different pathed precalced GI ?
    If this is a current limitation, is it possible to expose this parameter to Maya's render layer system or would this break everything for everyone else
    Thanks
    p.
    Patrick Macdonald
    Lighting TD : http://reformstudios.com Developer of "Mission Control", the spreadsheet editor for 3ds Max http://reformstudios.com/mission-control-for-3ds-max/
    You must right click on the label. I'm not sure if this was missing in the official 3.0. In any case, it can be done also with MEL:
    editRenderLayerAdjustment "vraySettings.lc_fileName"
    editRenderLayerAdjustment "vraySettings.imap_fileName2"
    V-Ray/PhoenixFD for Maya developer
