Vray Material : can't link an UV set while file is in amount
  • Vray Material : can't link an UV set while file is in amount
    Hi, I have an issue. I can't link an UV set ta a file that is plugged in the Amount parameter of a Vray Material.
    I can't see the file in the Relationship Editor. When I move the file in Opacity map I can see it, but not when it's in the Amount.
    I use Maya 2012 and Vray 3.0
    Thank you
    The same is for lambert. It seems to be a Maya thing. You can try with the 2d placement options of the uvw generator.
    V-Ray/PhoenixFD for Maya developer
      Okay, thank you for your answer.
