vray4maya_log.txt
  • vray4maya_log.txt
    Where do the vray logs show up now? In 2.4 I could see them at /tmp/vray4maya_log.txt. With 3.1/Maya 2016 that log file no longer appears.
    There are two environment variables, VRAY_FOR_MAYA_LOG_FILE_PATH and VRAY_FOR_MAYA_LOG_FILE_NAME that can change the path/name of that file. Are you sure you are not using one of them?
      I don't see those variables set in /etc/profile. Is there another place they would be?
      EDIT: They are also not present in /etc/launchd.conf
        Are you on OS X? Which version?
          My main workstation is on 10.10.4. I have render nodes and a render manager on 10.9.x and the logs don't show there either.
            I was able to get the log to show up again by adding a .plist to /Library/LaunchDaemons that points to the log location (adding VRAY_FOR_MAYA_LOG_FILE_PATH to /etc/profile alone didn't do it). I got the idea from a support ticket I had to resolve an issue with back burner permissions/vray licensing.
            I did have to manually set the permissions/owner/group for the .plist files and then restart.
            contents of .plist file should be
            Code:
            <?xml version="1.0" encoding="UTF-8"?>
            <!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd">
            <!-- This file was generated by the CHAOS GROUP installer. Please do NOT edit the file by yourself. -->
            <plist version="1.0">
                    <dict>
                            <key>Label</key>
                            <string>setenv.chaos_group.VRAY_FOR_MAYA_LOG_FILE_PATH</string>
                            <key>ProgramArguments</key>
                            <array>
                                    <string>/bin/launchctl</string>
                                    <string>setenv</string>
                                    <string>VRAY_FOR_MAYA_LOG_FILE_PATH</string>
                                    <string>/tmp</string>
                            </array>
                            <key>RunAtLoad</key>
                            <true/>
                            <key>ServiceIPC</key>
                            <false/>
                    </dict>
            </plist>
            if you have to do this and you aren't sure how to edit file permissions, there are two commands you need.
            sudo chown root:wheel /Library/LaunchDaemons/*plist file you created*
            sudo chmod 644 /Library/LaunchDaemons/*plist file you created*
              I'm guessing that /tmp was not writable... I was going to suggest redirecting it to a writable location.
