Saving the Lens Effects from network render
  • Saving the Lens Effects from network render
    Hi!
    Every time I send a render to Deadline, we never get the lens effects elements.
    It has the layer but Its always black, and the real color layer renders normal.
    V-ray 3.10.1
    MacOS yosemite.
    Thank you
    Johnny Grilo
    http://www.square-zero-one.com/
    https://www.facebook.com/squarezeroone
    Lens Effects are not supported through Batch Render and Render Management software so far.
    Lens Effects are VFB feature which only works when the image is being rendered in VFB.
      I think you can tell Deadline to render with the V-Ray stand-alone, not Maya batch.
      V-Ray/PhoenixFD for Maya developer
        I will try using stand alone.
        But this is a feature that I would like to have on the final render using Batch Render .
        Thank you
        Johnny Grilo
          Is this still the case with V-Ray 3.5? I did a batch render test last night and the lens effects weren't applied to effectsResult output.
          Maya 2020/2022
          Win 10x64
          Vray 5
            I'm afraid that the same stands for 3.5.
            Alex Yolov
            Product Manager
            V-Ray for Maya, Chaos Player
            www.chaos.com
              No problem.
              What's the best workflow? I batch render to vrimg and then just load it into the VFB, apply the lens effects then save from there.
              Maya 2020/2022
              Win 10x64
              Vray 5
                That's an option for sure, another one is to export .vrscene and render it with V-Ray Standalone with VFB enabled.
