setting VRAY_FOR_MAYA2016_PLUGINS_x64 environment variable in Maya.env doesn't work
  • setting VRAY_FOR_MAYA2016_PLUGINS_x64 environment variable in Maya.env doesn't work
    I'm trying to append the Yeti info to VRAY_FOR_MAYA2016_PLUGINS_x64 in Maya.env file and it's not working. If I make this edit:
    Code:
    VRAY_FOR_MAYA2016_PLUGINS_x64=/Applications/Autodesk/maya2016/vray/vrayplugins:/Applications/Yeti/bin
    and do getenv("VRAY_FOR_MAYA2016_PLUGINS_x64") in Maya, it returns this:
    // Result: /Applications/Autodesk/maya2016/vray/vrayplugins //
    Any idea how to make this edit work?
    Dave Girard
    Which OS is this?
      Os x 10.11.2.
      Dave Girard
        I don't think that this will work on any OS, at least in my experience. The best way would be to just export all variables in a shell script and run maya from that script.
        Alex Yolov
        Product Manager
        V-Ray for Maya, Chaos Player
        www.chaos.com
          ok. Thanks
          Dave Girard
            Why don't you try the following:
            1. Open up a terminal
            2. $ export VRAY_FOR_MAYA2016_PLUGINS_x64=/Applications/Autodesk/maya2016/vray/vrayplugins:/Applications/Yeti/bin
            3. $ open /Applications/Autodesk/maya2016/Maya.app
            If it works this way, we can help you set up these environment variables automatically.
            Yordan Miladinov V-Ray for Maya developer
              Yes, that works. That's what I've been doing but we're looking for a way to do this via GUI for customers that don't want to use Terminal.
              Dave Girard
                Well, OS X is progressively blocking all the ways we could do this, so I don't know...
                  Can you please check your /etc/profile and tell us if it sets the variable? It looks like Maya.env sets only these variables that are not already set by the time of starting up Maya. Thus, if you have VRAY_FOR_MAYA2016_PLUGINS_x64 defined in /etc/profile, whatever you place in Maya.env won't make a difference.
