One computer not rendering properly
  • One computer not rendering properly
    I have identical computers in a small render farm. One computer apparently isn't batch rendering with V-ray — although is works perfectly in DR. Through Backburner the computer appears to render normally yet returns .iff images so I'm thinking it's likely using Maya render instead of V-ray. The other computers work perfectly.
    The system software was recently reinstalled on this particular computer. I've installed Maya and V-ray twice without different results. Certainly I'm overlooking something. Any advice on what to check?
    Thanks!
    Troy Davis
    Animation Director
    atomicpictures.com
    I finally got the problem tracked down. Log file notes: maya binary file parse error: (6) corrupted file structure
    The system was running version Maya2016 sp4 instead of Maya2016 Ext.1 sp4
    Troy Davis
    Animation Director
    atomicpictures.com
      Thank you for your update Troy. Glad to hear that you managed to find the problem on this render node.
      Tashko Zashev | chaos.com
