I just notice a bug, or what ever, with lightmat, here is the situation:
simple example
poly box, add subd, or open subd, or viewport subd (make sure you turn on, render viewport subd)
and apply the lightmat, hit render and you should get the glowing sphere, BUT when you turn ON Direct Illumination, all subd's will be disabled???? Im not sure i understand this problem with Direct Ill
even if you convert the box into light object, same thing happen when you turn on the Direct Ill
any thoughts anyone?
cheers
simple example
cheers
