IES Light Shape
  • IES Light Shape
    It seems that if you change the light shape in an ies it will no longer get you soft shadows in the 3.15 build. It work just fine in 3.1.
    Is this temporary disable, or are you getting the same issue?
    Thanks in advance
    CG Artist - RnD and CG Supervision at Industriromantik
    It should calculate them from the IES shape only.
    Alex Yolov
    Product Manager
    V-Ray for Maya, Chaos Player
    www.chaos.com
      What do you mean?
      Under Light shape you can change it to say spherical or circular, where you can change a diameter. Increasing the diameter gave the ies light softer shadows.
      But this stopped working in 3.15 for some reason.
      Im talking about this:
        Sorry, got confused with another option.
        It works fine for me. What build (date/number) are you using? And if possible - can you attach an IES file if this happens with all IES files you try?
        Alex Yolov
        Product Manager
        www.chaos.com
          I dont get it to work in the 3.15.01-b26602-nightly.
          None of the ies files i've tried have worked. Im not allowed to attach an ies file here apparently, but here's the one in the image:
          https://mega.nz/#!S8I0yI6A!fJwIzpgwk...Gp2_hKD5fV0uXw
          It works just fine in 3.10.01-b26499-stable
            Where you able to recreate the problem? I could send a test-scene that renders incorrectly for me if that helps, but im not sure if that would matter.
              Thanks, we're looking at it and I'll let you know when there's an update.
              Alex Yolov
              Product Manager
              www.chaos.com
                Good timing, i have the same problem in a production.
                Hope it will be fixed quickly.
                www.deex.info
                  Try today's nightlies, it should be fixed there.
                  Alex Yolov
                  Product Manager
                  www.chaos.com
                    Sorry for a late reply. Havnt got around to try the new nightly until now.
                    Looks like its working! Thanks a ton
