XGEN not batch rendering
  • XGEN not batch rendering
    Hey Guys,
    Currently I am using MAYA 2016 Extension 1 SP5 and I followed all the instructions on batch rendering xgen like exporting patches and adding an additional frame to the end frame of my patch export but for some reason it will only render one section of the fur.
    Does anyone know how I can resolve this issue?
    Thanks
    Richard Kim
    These are the warning that i get
    // Error: XGen: Caf Error. Removing patch: XG_RENDER_gen_back_headFeather_shaft //
      Are you having this problem when rendering locally or is it on a farm? or in DR? Any chance we can get a (sample) scene so we can take a look? Basically it should work right off as the instructions say.
      Also what V-Ray are you using?
      Alex Yolov
      Product Manager
      V-Ray for Maya, Chaos Player
      www.chaos.com
        hey yolov,
        I am using Vray 3.1. I can preview render the scene but when I batch it locally and in the farm the fur does not render as a whole. Unfortunately I can not give a sample scene because of NDA's we have signed. I have multiple meshes connected into one collection would that cause an issue?
        Richard Kim
          Do you have any error messages or warnings in the V-Ray log on the farm?
            XGen Version: C:/Program Files/Autodesk/Maya2016/plug-ins/xgen/ Build Date: Nov 30 2015 12:10:16
            Error: XGen: Alembic error. No geometry named 'xgen_feather_tail_a_shaft' found in file(frame): M:/directors/peter_sluszka/mcds38/mcds38_angrybirds/06_3d/maya/lib/char/red/components/fur/workshop/red_fur_workshop_0055__redCollection.abc( 5.0000)
            Error: XGen: Alembic error. No geometry named 'xgen_feather_tail_b_shaft' found in file(frame): M:/directors/peter_sluszka/mcds38/mcds38_angrybirds/06_3d/maya/lib/char/red/components/fur/workshop/red_fur_workshop_0055__redCollection.abc( 5.0000)
            Error: XGen: Alembic error. No geometry named 'xgen_feather_tail_c_shaft' found in file(frame): M:/directors/peter_sluszka/mcds38/mcds38_angrybirds/06_3d/maya/lib/char/red/components/fur/workshop/red_fur_workshop_0055__redCollection.abc( 5.0000)
            Error: XGen: Alembic error. No geometry named 'xgen_back_headFeather_shaft' found in file(frame): M:/directors/peter_sluszka/mcds38/mcds38_angrybirds/06_3d/maya/lib/char/red/components/fur/workshop/red_fur_workshop_0055__redCollection.abc( 5.0000)
            Error: XGen: Alembic error. No geometry named 'red_hi_cn_body' found in file(frame): M:/directors/peter_sluszka/mcds38/mcds38_angrybirds/06_3d/maya/lib/char/red/components/fur/workshop/red_fur_workshop_0055__redCollection.abc( 5.0000)
            Warning: XGen(1): No pref specified for: XG_RENDER_gen_feather_tail_a_shaft. Popping may result.
            Warning: XGen(1): No base geometry specified for: XG_RENDER_gen_feather_tail_a_shaft. Cant render patches on this geometry.
            Error: XGen: Caf Error. Removing patch: XG_RENDER_gen_feather_tail_a_shaft
            Warning: XGen(1): No pref specified for: XG_RENDER_gen_feather_tail_b_shaft. Popping may result.
            Warning: XGen(1): No base geometry specified for: XG_RENDER_gen_feather_tail_b_shaft. Cant render patches on this geometry.
            Error: XGen: Caf Error. Removing patch: XG_RENDER_gen_feather_tail_b_shaft
            Warning: XGen(1): No pref specified for: XG_RENDER_gen_feather_tail_c_shaft. Popping may result.
            Warning: XGen(1): No base geometry specified for: XG_RENDER_gen_feather_tail_c_shaft. Cant render patches on this geometry.
            Error: XGen: Caf Error. Removing patch: XG_RENDER_gen_feather_tail_c_shaft
            Warning: XGen(1): No pref specified for: XG_RENDER_gen_back_headFeather_shaft. Popping may result.
            Warning: XGen(1): No base geometry specified for: XG_RENDER_gen_back_headFeather_shaft. Cant render patches on this geometry.
            Warning: XGen(1): No pref specified for: XG_RENDER_:red_hi_cn_body. Popping may result.
            Warning: XGen(1): No base geometry specified for: XG_RENDER_:red_hi_cn_body. Cant render patches on this geometry.
            Error: XGen: Caf Error. Removing patch: XG_RENDER_:red_hi_cn_body
              Ok. Can you get us the full log (vray4maya_log.txt)?
                Here it is Vlado
                Thank you so much for looking into this. Here is a link a Log
                https://drive.google.com/file/d/0B7R...ew?usp=sharing
                RIchard Kim
                  I doubt there is something V-Ray related in this issue. These all seems like XGen errors.
                  V-Ray/PhoenixFD for Maya developer
