I’ve been having some troubles with membership of vrayobjectproperties lately.
I am trying to build a scene in the commandprompt (mayapy), but when I reference in a shader and assign it to the components of a mesh, I am no longer able to assign the mesh to vrayobjectproperties. Querying the membership of vrayobjectproperties displays the mesh as being a member, but when I open the scene through the UI it is not.
When I do the exact same thing in the scriptEditor (running maya with ui) it seems to work just fine.
A workaround for this is to create a new set after creating the vrayobjectproperties, but I thought I would just share this with you so you don’t have to go through the same headache.
I’ve written a bit of code to demonstrate:
http://mortenbohne.dk/maya/bugReport...pertiesTest.py
Note that the script will create a folder (vrayPropertiesSets) in your userPrefsDir containing 3 files: refshader.mb, setsTest.mb, setsTest_extraset.mb
refshader.mb is the shader being referenced in to the other files, setsTest.mb is the setup where meshes were added directly to the vrayobjectproperties (note that the plane has componentshading from a referenced shader, and is not part of vrayobjectproperties) setsTest_extraset.mb has a set holding the members, making all meshes part of vrayobjectproperties.
I'm running maya 2016SP5.
V-Ray for Maya version 3.10.01 from Jul 18 2015, 10:56:00
V-Ray core version is 3.25.01
Would be nice to be able to expect the same behavior no matter how you build your scene
cheers!
cheers!
