IR prepass / animation error
  • IR prepass / animation error
    Submitted to ChasoGroup support, but haven't heard anything back yet - - so I'm trying the forums to see if anyone here has a solution:
    I encountered a significant error when trying to resume a stopped render that uses the IR prepass.
    Following the instructions here, but using Maya 2016 SP4:
    http://docs.chaosgroup.com/display/V...ing+Objects+II
    Using IR Animation (prepass) + LC setting I rendered out frames 800-1000. Then using Animation (rendering) setting with no LC I rendered frames 800-815. Everything is looking great! Upon restarting the render from frame 815, I noticed a significant difference in the GI pass between frame 815 of the first round of render and the second.
ID:	883734Click image for larger version
    Any ideas why this is occurring? Or how to fix it? It seems to be similar in nature to the issue jasonazure was having:
    http://forums.chaosgroup.com/showthr...radiance-files
    Thanks,
    Can you send us the scene or a portion of it so we can run some tests?
    Could you tell us your V-Ray version?
    Alex Yolov
    Product Manager
    V-Ray for Maya, Chaos Player
    www.chaos.com
      I PM'd you a link to the scene file.
      This issue happens with both VRAY 3.10.01 and 3.30.01
        OK, thanks. I'll have a look and get back to you with what I find.
        Alex Yolov
        Product Manager
        www.chaos.com
          The Support Team is a bit overloaded after the Maya release and there is a delay in our replies.
          Can you give me the ticket number so I could check what's going on with your case?
            Ticket #882979
            Thank you Svetlozar
