Reflection Subdivision greyed out/ locked
There's been a bigger change in how sampling is handled. You can enable 'use local subdivs' in the dmc sampler rollout of the render settings to get the subdiv slider back to work.
(But then you also might want to change the min shading rate and the max subback to a lower value. VRay is now trying to make it as easy as possible to get good results when startign out with a new scene.)
- Likes 1
You can take a look here: http://docs.chaosgroup.com/display/V...plerParameters
When use local subdivs is disabled, V-Ray will use the Min Shading Rate to control the image quality.
Since V-Ray 3.0 camera DoF is controlled by the AA samples.
