VrayTriplanar and Normal Maps
  • VrayTriplanar and Normal Maps
    it seems, that normal maps won't work as desired if one uses VrayTriplanar to map them,
    because of the nature of the VrayTriplanar mapping (which uses 3 planes, right?).
    Basically one side uses +X but the opposite too (but should project from the other side).
    Would it generally be possible to map with 6 planes ?
    Cheers
    Dominik
    Dominik Markota | Head of CGI | Senior Shading & Lighting TD @ Serviceplan MAKE
    We can fix the normal maps - can you post some sample scene that I can use for testing?
      Hi Vlado,
      I've just sent the scene to the support team mail address.
      Thanks for looking into it
      Dominik
        Hi guys,
        any news on that topic?
        Cheers!
        Dominik
          We are sorry to report but the issue is not solved yet.
          We'll keep you posted.
            Any news on this?
            Website
            https://mangobeard.com/
            Behance
            https://www.behance.net/seandunderdale
              I think this was fixed a long time ago in the nightlies.
                Good to know...Our IT have a rule of not using the nightlies as they feel its unstable to be using versions that aren't a full release. I think compiling a list of the fixes in the nightly might persuade them the nightlies are worth using.
                Website
                Behance
                  Each nightly build folder includes release notes where you can see what is changed.
