We have been using adaptive sampling but seeing all the push for the progressive we decided to try it in the pipeline.
Our usual approach is to work out the sampling setting (min/max subdivs, contrast etc) on a little region. After a fair bit of experimenting on my sample region I ended up with settings I liked:
min shading rate: 6
min/max subdivs 1-15
noise threshold: 0.025
the noise threshold is higher than expected and max subdivs lower than usually but the result was smooth enough.
however the same part of the image when rendered without region looks very different and has much more noise.
the right one is a section from full res render
Looking at render stats they are not even close.
RENDER REGION:
Sampling level reached: 15.20 subdivs (622 passes)
Number of raycasts: 518043891 (6245.71 per pixel)
Camera rays: 12991553 (156.63 per pixel)
Shadow rays: 135790702 (1637.14 per pixel)
GI rays: 69601802 (839.14 per pixel)
Reflection rays: 70941 (0.86 per pixel)
Refraction rays: 0 (0.00 per pixel)
Unshaded rays: 318002894 (3833.95 per pixel)
Number of light evaluations: 264101600 (127.36 per pixel)
Number of intersectable primitives: 162836
FULL FRAME:
Sampling level reached: 15.20 subdivs (801 passes)
Number of raycasts: 5600395985 (2700.81 per pixel)
Camera rays: 168959981 (81.48 per pixel)
Shadow rays: 1472087601 (709.92 per pixel)
GI rays: 824378546 (397.56 per pixel)
Reflection rays: 2659636 (1.28 per pixel)
Unshaded rays: 3339764198 (1610.61 per pixel)
Number of light evaluations: 2856628836 (1377.62 per pixel)
in both cases the same sampling level was reached 15.20 but the amount of passes was different. Why isn't it consistent? Other progressive renderers like maxwell do not behave that way.
is this how vray works? or a bug? can someone explain a bit how the algorithm works and why the passes seem to dynamically change?
shouldn't the noise be exactly the same with the same contrast threshold?
thank you,
Pawel
min shading rate: 6
RENDER REGION:
FULL FRAME:
thank you,
Pawel
