Vray Environment Fog / Volume is still visible with primary visibility=off?
  • Vray Environment Fog / Volume is still visible with primary visibility=off?
    i think its the same issue:
    http://forums.chaosgroup.com/showthr...ume+visibility
    In our project we are rendering an earth with an atmosphere (Sphere with vray Material / Opacity = 0 and a vrayenvironmentfog volume shader). In the renderlayer with the other objects, the earth has an vrayobjectproperty and primary visibility set to off... but the volumeshader is still visible.
    Am i doing something wrong or is this a bug?
    Maya 2016 SP5
    VRay 33001_N26664
    Best regards
    David
    Hi David,
    The information form that thread is still valid
    visibility currently only controls the surface of the object, not its volume.
    But you can use the Ray filter switch to remove the fog from a certain layer.
Name:	2016-03-21 12_03_15}.png
    Tashko Zashev | chaos.com
      Ok, i missed that.... but works great, thanks
