use image sequence not working?
  • use image sequence not working?
    how can i get an image texture sequence to work in vray? as soon as i enable "use image sequence" in the 2d file node it renders without a texture. the sequence plays fine in the viewport.
    naming convention is : example.000.tif
    I tried searching but have not found a solution. using 3.35 nightly
    What the build number and date of the 3.35 nightly that you're using?
    You can get those from the first lines of the Maya Output window.
    Alex Yolov
    Product Manager
    V-Ray for Maya, Chaos Player
    www.chaos.com
      V-Ray for Maya version 3.35.01, revision 26724 from Apr 9 2016
      I am still not able to do this. this should literally take me 5 seconds to do and its been two days. The one thing I have noticed is anything past frame 100 works.
      however if i change the expression to counter this by adding 100 (file1.frameExtension=frame +100; ) it still does not work. If i change 001 to 1 it works.
      however this seems like a big bug on vrays part.
        The bad news is that it's a bug. The good news is that we're already working on it. I'll update the thread once it's fixed.
        Alex Yolov
        Product Manager
        www.chaos.com
          ... disregard, Alex keyboard seems to be faster than mine
