Cannot load vrmesh file @ 1001th vrmesh
  • Cannot load vrmesh file @ 1001th vrmesh
    We have a huge amount of vrmeshes in a scene here. When attempting to render this on Windows, it works just fine. On Linux (CentOS 7) however, the first 1000 vrmeshes are loaded fine but then we get "V-Ray warning: Could not load mesh file" for all of the following vrmeshes. Please note, we do *not* get the "Max opened files" error.
    So in my /etc/security/limits.conf on the farm machines, I double checked, and I've got the following set:
    Code:
    *         hard    nofile      500000
    *         soft    nofile      500000
    root      hard    nofile      500000
    root      soft    nofile      500000
    IRUser    hard    nofile      500000
    IRUser    soft    nofile      500000
    The user "IRUser" is the one performing renders and it's supposed to be able to load all these vrmeshes, as far as I know. We actually hit the "Too many files opened" a while back on CentOS 6, and fixed it by upping the values in this config file. But now, it seems this setting isn't sufficient.
    Do you have any idea what I'm missing?
    I'm not aware of any other way of upping the max number of allowed opened files in CentOS 7.
    Best Regards,
    Fredrik
    We have a CentOS 7 install here; let us do a few tests.
      Great, thanks. This happened with 3.30.02 stable build 26678 for Maya 2015 Extension 1 Service Pack 6 on CentOS Linux, 7.2.1511, Linux-3.10.0-327.13.1.el7.x86_64-x86_64-with-centos-7.2.1511-Core.
      Talk about a versions report!
      Best Regards,
      Fredrik
        All guides I could find on the internet mention that you have to add this
        Code:
        fs.file-max = 100000
        to /etc/sysctl.conf and then run sysconf -p
        Have you done this?
        Also how are you starting V-Ray? If it is as a systemd service then you need to modify the service script, too.
        Here is an example how to do it for mysql - https://naveensnayak.wordpress.com/2...imit-centos-7/
        V-Ray developer
          No I haven't tried that. Seems like something new with CentOS 7?
          I'm giving this a try now.
          Best Regards,
          Fredrik
            Unfortunately, setting fs.file-max in /etc/sysctl.conf didn't help
            Best Regards,
            Fredrik
              We're rendering via mayabatch. So I'm not using V-Ray standalone. Anything I need to do in this case?
              Best Regards,
              Fredrik
                Have you restarted all your shells?
                What is the output of ulimit -a in a terminal?
                V-Ray developer
                  Just rebooted, to be sure.
                  Code:
                  [root@bs01gen04 ~]# ulimit
                  unlimited
                  [root@bs01gen04 ~]# ulimit -n
                  500000
                  [root@bs01gen04 ~]# ulimit -a
                  core file size          (blocks, -c) 0
                  data seg size           (kbytes, -d) unlimited
                  scheduling priority             (-e) 0
                  file size               (blocks, -f) unlimited
                  pending signals                 (-i) 256849
                  max locked memory       (kbytes, -l) 64
                  max memory size         (kbytes, -m) unlimited
                  open files                      (-n) 500000
                  pipe size            (512 bytes, -p) 8
                  POSIX message queues     (bytes, -q) 819200
                  real-time priority              (-r) 0
                  stack size              (kbytes, -s) 8192
                  cpu time               (seconds, -t) unlimited
                  max user processes              (-u) 500000
                  virtual memory          (kbytes, -v) unlimited
                  file locks                      (-x) unlimited
                  I did change some things to /etc/security/limits.conf prior to the reboot:
                  Code:
                  *         hard    nproc       500000
                  *         soft    nproc       500000
                  I still cannot load more than exactly 1000 vrmeshes before triggering "could not load mesh file".
                  Best Regards,
                  Fredrik
                    And if you run mayabatch from this same console/terminal it won't be able to open all the needed files?
                    V-Ray developer
                      What the?!
                      When running the render command in that shell, all vrmeshes load up just fine.
                      Best Regards,
                      Fredrik
                        Then again my question: how are you starting mayabatch?
                        Deadline, some other render manager, custom system?
                        V-Ray developer
                          I'm starting mayabatch via Pixar's Tractor. Mayabatch is not started directly, but through a Python wrapper script.
                          So, Tractor makes the Linux machine execute "python script.py " with a bunch of arguments such as which renderer to use and some custom config.
                          And the executable which is launched by Python is called "Render", not "mayabatch".
                          Best Regards,
                          Fredrik
                            Just ran this as a test from my wrapper script:
                            Code:
                            import resource
                            # the soft limit imposed by the current configuration
                            # the hard limit imposed by the operating system.
                            soft, hard = resource.getrlimit(resource.RLIMIT_NOFILE)
                            print 'Soft limit is ', soft
                            print 'Hard limit is ', hard
                            During the failing render, this showed:
                            Soft limit is 1024
                            Hard limit is 4096
                            ...so obviously the system wide setting does not apply in that shell for some reason.
                            Best Regards,
                            Fredrik
                            • #15
                              Thanks guys for helping out. This is obviously a Pixar Tractor issue. I'll report back when I solve this. Sounds like I need to configure the Tractor client to allow a larger amount of opened files (via ulimit perhaps).
                              Best Regards,
                              Fredrik
