Possible Sun + Sky bug with buckets
  • Possible Sun + Sky bug with buckets
    First time I've seen this in a scene, I have a room setup with a sun + sky. All rendering on the local machine (NO DR).
    However I get these artefacts on the wall? They are not specular artefacts but direct light coming from V-Ray Sky via a portal light.
    I can send in the scene if need be, just wanted to make sure if this was a known bug before doing so.
Name:	2016-05-03 16_17_44-Render View.png
    Maya 2020/2022
    Win 10x64
    Vray 5
    It's not a bug, just hard to sample situation. Increasing the min. subdivs for AA should solve the problem. Alternatively, increasing the sampling for the refractions (if those are glossy refractions) will help too.
      Thanks for the reply Vlado.
      I was using the 1-24 method this time. I just tried then with the older 1-100 universal method and while it's still kind of visible I can get away with it.
      Thanks for the help.
      Maya 2020/2022
      Win 10x64
      Vray 5
        It might be worth trying 2/24 or 3/24 as well.
          2/24 worked quite well - thanks!
          Maya 2020/2022
          Win 10x64
          Vray 5
