Vray Toon Outline noise
  • Vray Toon Outline noise
    Hello, I am try to get a hand drawn look with my models, and can only get close to it when I set the settings to their lowest. But I am experiencing unwanted noise on the model which I do not know how to fix. I am just learning Vraytoon, so any help would be appreciated.
    Thank you for your time.
    Try increasing the "overlap" treshold, or the "normals" one and see if it helps.
      hi, I tried both and increasing the overlap got rid of some of the noise, but I lost some of the lines in the process. Anything I can do to fix it?
        Not sure right away; can you post just that part of the scene f.e. part of the head, ear and neck so that we can play with it? There's no need for the full geometry.
          Sure, included is just the bust and the toon settings to .001 with a light dome.
            I think I managed to remove the artifacts without loosing the toon-lines with the following settings:
            scene: http://ftp.chaosgroup.com/support/scenes/Toon_Test1.mb
              Thank you so much, its more workable now.
