Frame buffer problem!
  • Frame buffer problem!
    So im working on a job and cannot get the vray frame buffer to show up & it's really annoying! if I then load up a scene using a different renderer the frame buffer then pops up! ... go back to the scene using VR & it goes again. I restarted my machine & it fixed it , but 30 mins later it's gone again ........ anyone have any ideas on why this would be happening & how to fix it ?
    Thanks
    Was it by any chance minimized when closing the scene? If yes, it's a known bug and it's already logged to our bug-tracker. You can verify this by querying its position when it disappears by running the below lines in a MEL tab in the script editor:
    Code:
    vrayShowVFB;
    window -q -topLeftCorner vfbPanelWindow;
    And if it shows really weird number, edit its position like this:
    Code:
    vrayShowVFB;
    window -e -topLeftCorner 1 1 vfbPanelWindow;
    Alex Yolov
    Product Manager
    V-Ray for Maya, Chaos Player
    www.chaos.com
      Thanks, it seemed the VFB was hidden in the scene being referenced. once i fixed it in that scene, it seemed to work ok in the main render scene.
      Thanks
        Can you reproduce the problem again if you revert the modifications you've done in the reference scene?
        V-Ray developer
          This is happening to me in a new scene with some elements and nothing Reference, its very annoying.
          Even if I exit Maya and re open it.
          Maya 2016.5
          Vray 3.4.03 Stable Nightly Build from July 19th 2016
          Windows 10
          This was happening before as well before I changed to this new Nightly Build.
