Hey there,
We're keen on Maya's new render setup layers, together with VRay v3.4.
I'm running into an issue where Vray render's black frames when I'm switching the new layers view python commands.
I thought it was a Maya issue (still might be) but doing the same test with other render-engines we have (Redshift and MayaSoftwareRender) worked as expected.
Here's the steps to reproduce the issue:
- I've setup a basic scene, in 2016.5, using the new layers (maya2016_5_layers_simple_test.zip)
- an ambientLight, camera, Sphere and Cube, each in it's own layer and collection
- I ran this python code to switch between the renderSetupLayers and render 1 frame
Vray will render both layers, but as black frames.
Now, if I'll just switch the the render engine to be MayaSoftwareRender (or Redshift) and ran the code, it will render correctly.
Also, if it help or confuses even more (
- doing the same process in mayapy.exe will give the same result (Vray will render black frames, Redshift&MayaSoftware will render correctly)
- calling render.exe to do the render, will render correctly but it won't render any Render Elements...
"C:\Program Files\Autodesk\Maya2016.5\bin\render.exe" -s "6" -e "9" -b "1" -rl "cube" -threads "8" -rd "c:/temp/" -proj "//eru/DEEPM/images/episodes/light/light_tests/light_tests_110" -renderer "vray" "c:\simple_scene.ma"
I have a feeling it's related to Maya's refresh issue in the new layers setup, but since it's working for the other renders, I thought I'll start asking here.
any idea would help a lot,
thank you,
Asi
Code:
import maya.app.renderSetup.model.renderSetup as renderSetupModel rendersetup = renderSetupModel.instance() layers = rendersetup.getRenderLayers() for layer in layers: print ">>> {} <<<".format(layer.name()) layer.makeVisible() cmds.vrend(camera="camera1") # Vray render #cmds.render() # MayaSoftware
Code:
import maya.app.renderSetup.model.renderSetup as renderSetupModel rendersetup = renderSetupModel.instance() layers = rendersetup.getRenderLayers() for layer in layers: print ">>> {} <<<".format(layer.name()) layer.makeVisible() #cmds.vrend(camera="camera1") # Vray render cmds.render() # MayaSoftware
thank you,
Asi
