I believe this issue is being looked at by the support team, but please allow me to post it here in case there are people who have run into the same issue.
I have many cards (poly planes) with image sequence textures.
I'd like to be able to assign only 1-set of VRayLightMtl + file texture node to all the cards, with each card gets different frames from the sequence. I use VRayUserString_attrName to do it:
https://docs.chaosgroup.com/display/...userattributes
I use an expression to set VRayUserString attributes on each card with 4-padded frame numbers.
For example:
[at frame 1]
card_a = texture frame 0001
card_b = texture frame 0006
card_c = texture frame 0015
card_d = texture frame 0029
[at frame 2]
card_a = texture frame 0002
card_b = texture frame 0007
card_c = texture frame 0016
card_d = texture frame 0030
[at frame 11]
card_a = texture frame 0011
card_b = texture frame 0016
card_c = texture frame 0025
card_d = texture frame 0039
This works when rendered only one frame at a time, but it stops working when rendered in batch. It renders all frames the same as frame 1, which seems that VRayUserString is not working as it should.
I can provide a simple test scene data (about 8MB zipped).
Should I put a box.com download link?
Regards,
-Tadao
For example:
[at frame 1]
[at frame 2]
[at frame 11]
Regards,
-Tadao
