Maya keep crashing when using IPR
    It seems the crashes can be addressed to this specific Maya version - 2014. Tested the scene of 2016, 2017 and Rt/IPR works a lot more stable even if i follow every step that crashes V-Ray / Maya 2014.
    The issue is now logged into our bug tracker and our developers will work on it.
    Tashko Zashev | chaos.com
      I noticed the same thing. Doing IPR with the original scene in Maya 2017 and newer nightly builds is fairly stable. I haven't experienced any crash so far. Hope you find what's causing the crash for Maya 2014/V-Ray.
      always curious...
        It is a Maya bug if I remember correctly.
        I think they fixed it with one of the service packs.
        What exact version are you running?
        V-Ray developer
          I installed Maya 2014 SP4. But telling from the my the version number of 16.0.0.0 in Control Panel, I assume it's still the first release of Maya 2014.
          So you are saying maybe the crash can be addressed if I make sure upgrading to the latest Maya 2014 service pack?
          always curious...
            I think so, but I might be wrong. I think some of the crashes disappeared with SP3.
            Use Help -> About Maya to check which service pack you have installed.
            V-Ray developer
            • #21
              That's exactly where I went to check and it shows no SP.
              Tashko, are you able to re-produce this crash in Maya 2014 SP4 with the sample file I uploaded?
              always curious...
              • #22
                The same happened here after installing SP4 so I went through a new installation process with Maya 2014 SP3 and now IRP/RT works more stable with your scene. Just a few minutes of testing but no crashes while working on the scene lighting.
                • #23
                  Funny that SP3 is more stable than SP4 in this regard. Can you confirm it's good to go in SP3 after some more tests on your end and I will update my Maya 2014 to SP3.
                  Thanks!
                  always curious...
                  • #24
                    Thanks!
                    I think it is save to update to SP3.
                    • #25
                      Thanks Tashko. Just did the upgrade and will report here if I run into the same issue.
                      always curious...
