Subdivision and OpenSubdiv Attributes - Preserve geometry borders
  • Subdivision and OpenSubdiv Attributes - Preserve geometry borders
    Case:
    If you have a plane and add "Subdivision Attributes" to the plane. (https://docs.chaosgroup.com/display/...YA/Subdivision)
    Question:
    How do you preserve geometry borders? (I know you can make hard edges to the geometry. But this doesn't give me 100% sharp edges.
    Is this possible to do this with Subdivision Attributes? I know you can do it with OpenSubdiv Attributes (Osd Preserve geometry borders – specifies whether geometry borders are preserved or not).
    Best regards
    Jacob Hansen
    Best regards
    Jacob Hansen
    Laerdal Copenhagen
    I'm not sure about your case exactly without seeing a sample scene, however you can specify an edge using crease edge tool, then opensubdiv will recognize that and keep it sharp.
    Imho the preserve geometry border should preserve edges of the geometry which are open, however it seems it does not.
    Dmitry Vinnik
    Silhouette Images Inc.
    ShowReel:
      ... sample scene
      http://www.wireguruji.dk/vray/OpenSu...ubdivision.zip
      Best regards
      Jacob Hansen
      Laerdal Copenhagen
        We have no option to preserve geometry borders with V-Ray subdivision. You will have to use OpenSubdiv in that case.
          ...Thanks for the reply. And good to know.
          In future releases i hope that Subdivision Attributes will be able to Preserve geometry borders. So it´s possible to take advantages of view-dependent rendering and Preserve geometry borders.
          Best regards
          Jacob Hansen
          Laerdal Copenhagen
          Best regards
          Jacob Hansen
          Laerdal Copenhagen
            Yes, I will make a note about it.
              I also hope that Subdivision Attributes will be able to render with Crease
              Best regards
              Jacob Hansen
              Laerdal Copenhagen
                This we won't do, unfortunately. You'll have to use OpenSubdiv for that.
                  ... roger
                  Best regards
                  Jacob Hansen
                  Best regards
                  Jacob Hansen
                  Laerdal Copenhagen
