I have this super weird problem right now. I am working on a scene setup by someone else that was setup as a linear gamma workflow. Now I've been working on changing some of the multimattes, one material setting was changed and 2 render elements were added. EVERYTHING else has remained the same. None of the settings in terms of gamma settings were touched.
Now when I compare this to the earlier version, the final render appears a lot darker. When viewed in the frame buffer and when viewed in Nuke. It's not so dark though that when I put a gamma of 2.2 correction on it in Nuke it's the same again. I've been checking the gamma settings on all the shaders and in the color mapping settings, but it's all exactly the same as the first version.
I have litterally NO idea what's causing this. I'm at a total loss.
What could cause this????
