Making Vray Rect Lights transparent
  • Making Vray Rect Lights transparent
    Hey guys,
    one of our Maya people has a problem. In Max I can make a textured Vray Light easily transparent using the "Alpha from RGB intensity" option. That way the light becomes transparent where the map is black. You can see the effect in the attached pictures.
    No here comes the question: How can this be achieved in Maya? I fiddled around with the Alpha is Lumincance option, but that doesn't work. Plugging a map into the alpha gain slot also didn't help.
    Regards
    Oliver
ID:	885938Click image for larger version
    here is the solution.
    Because of the very unintuitiv formulation, I need´s years to find that trick!
    Rect Tex A mean´s RT - Alpha.
    You can map it or set it to black - means zero.
    Cheers
    Vray 3.5, Win10
    www.3dcompani.com
