vector displacement scene...
  • vector displacement scene...
    could we get this vector displacement scene from the tutorial...? the mudbox scene and the vray one would be great..
    i cant get it working, even with ptex... it worked in the past...
    i tried every color management things but no luck... every face is seperated...
    cheers...
    ok than the other way around...
    here is my scene... as you can see the values are clipped and i get seams...
      scene file is to big to upload...
      https://drive.google.com/file/d/0B85...ew?usp=sharing
        Originally posted by FSGFX View Post
        Hi FSGFX,
        There were a bunch of things you need to do to get it to work. I think you need to set your ptex set up resolution level to be at least twice the resolution you have now. Then once exported in vray you have to set a bunch of options. For example, you use normal displacement, but you need to either use vector absolute or object (depending on how you exported the ptex) In ptex you need to turn off filtering entirely. Also you need to set the displacement bounds to -10/10, so there is no clipping then it will work correctly. See attached
        https://drive.google.com/open?id=0B-...lRYcXpPSmdaaWs
        Dmitry Vinnik
        Silhouette Images Inc.
        ShowReel:
          thanks Dmitry... as you can see in the imabe above i have set the disp to vector absolute in vray...
          i will check now your files...
          cheers...
            does work with your scene and object space...
            does not work with absolute... but we need that for animation...
            hmm... strange...
              Yeah what maya version are you on? When I opened your scene those settings were not set.
              Regradless try uprez your ptex in mudbox and re export...
              Dmitry Vinnik
              ShowReel:
                im on maya 2017.2
                i will try tomorrow... now starwars...
                  Set the "Displacement bounds" to "Explicit" and the Min value to something like RGB -10, -10, -10 and the Max value to RGB 10,10,10 and it should be better.
                  Other than that, see Dmitry's notes.
                    V-Ray works just fine with object space and animation; just make sure the Ptex file contains mesh information.
                      object space does work... but i still cant get absolute tangent to work....
                        So just use object space? Like I said, it will work fine with deformation.
                          yes... will do...
                          thanks...
                            there are a lot of artefacts all over if you take a closer look...
                            even in the example file from Morbid Angel...
                            object space is not the solution for a clean replica of the highress...
                            im not sure if the issue is caused by vray or mudbox itself...
