Vray IPR networked textures issue
  • Vray IPR networked textures issue
    Hello,
    I am having issues with network textures in Maya 2016.5 using Vray 3.40.06 when using IPR on a Windows 10 workstation. My central file server is setup using UNC paths and will render all the textures fine within a normal render but whenever I try using IPR the textures will render out black. IPR works normally if I copy the textures to a local drive.
    Any help would be much appreciated.
    Thanks in advance.
    Okay, browsing the forums some more it seems like it was a vray render slave service causing my issue as seen here:
    http://forums.chaosgroup.com/showthr...s-render-black
    So, I should be good to go for now!
      Glad you found the solution. Let us know if you need any additional assistance.
      Miroslav Ivanov
      Chaos Cosmos
