Z-Brush > Maya > Vray Normals Issue
  • Z-Brush > Maya > Vray Normals Issue
    Hey all,
    I've got a problem with rendering normal maps properly within Vray for Maya.
    My process:
    I create my hi-res version in Z-Brush (mostly for creating fabric wrinkles in my work), then using the Multi-Matte exporter I export out the low-res and the normal map. Settings below:
Name:	Zbrush Export.PNG
    Then in Maya I import in the low res mesh apply a shader to it. The set up here is the OSL Fabric shader plugged in to a Vray Bump shader. The Vray Bump shader is set to "Normal map in tangent space", and the file is set to "Raw" colour space.
    The object will render fine if I hit "3" smooth before rendering, see below:
    But it will look faceted if I don't hit smooth before rendering... I need it to render out without being pre-smoothed as a lot of the time I need Normal Maps to be applied to Vray Proxy objects that cannot be smoothed before rendering.
Name:	Capture Faceted.jpg
    Can anyone help me achieve this?
    So you get that problem even without a proxy? Could you send us the mesh and normal map?
    V-Ray for Maya dev team lead
      Yeah, it still happens whenever I try a normal map on a low(er)-poly object. This is by no means a decent model or normal map, but there's something here that demonstrates it:
      https://we.tl/pA0lTJxAKy
        Do you get the same on a VrayMtl?
          can you repost this scene, its gone from wetransfer. I assume you smoothed the normals in maya prior to applying the normal map?
          Dmitry Vinnik
          Silhouette Images Inc.
          ShowReel:
            If possible, please re-attach the scene since like Dmitry said the link expired.
            Let us also know if the issue happens with V-Ray materials or it only occurs with OSL-shader.
            Let us know if it works as expected when the subdivisions is added from V-Ray attributes> Subdivision and Displacement or OpenSudivs ones.
            And finally, does the same thing happen with other render engines?
              It seems like the vertex normals on your mesh are not smooth.
              You can see what I mean on the screen shot below:
              Modeling > Mesh display > soften edge seems to fix the faceting.
              Please tell us if that fixes your problem
