Maya crashed with Cache bitmaps between renders enabled
  • Maya crashed with Cache bitmaps between renders enabled
    I have a scene that was originally created in Maya 2014 and Vray 2.x. I open it up and rendered in Maya 2017 with Vray nightly (Standalone ver. 3.57.01 Build 27199). When I untick "Cache bitmaps between renders" (Render Settings>Overrides>Rendering), regular render and IPR run as normal. However, when I tick "Cache bitmaps between renders", the very 1st rendering runs normally. But Maya crashes every time after I hit stop and hit render again (essentially the 2nd time trying to render after open the scene).
    If I assign a default VrayMtl to all scene geos and render with the "Cache bitmaps between renders" ticked, Maya doesn't crash.
    I can upload all assets including textures if necessary. The archived project is about 900MB.
    Thanks,
    Jason
    always curious...
    Hi Jason,
    If you don't have access to our FTP yet, please drop an email to support@chaosgroup.com
    Or just use any file transfer service and send us the download link to the same email address. Thanks!
    Tashko Zashev | chaos.com
      Thanks Tashko. Will drop an email to the support for FTP access and then upload.
      always curious...
        Thank you Jason. You have a reply from us.
          I am uploading to the FTP. Will reply to the support on file name.
          The project is set up in Maya 2017 update 2 with nightly build (Standalone ver. 3.57.01 Build 27199) on Windows 7 x64.
          Thanks,
          Jason
          always curious...
            I have uploaded the archived project and reply the support. Please let me know if you have any issue reproduce the crash.
            Look forward to hearing back.
            Thanks,
            Jason
            always curious...
              Unfortunately we are not able to reproduce the crash here. I've replied on your ticket with details and questions for further troubleshooting.
                Hi Tashko,
                Before I go ahead and generate the crash dump file, can I confirm with you that it's the "2nd time" you try to render the scene with "Cache bitmps between renders" enabled?
                As I mentioned in the first post, when I open the scene, make sure the "Cache bitmaps between renders" is enabled, and hit render. It is totally fine. So, the very first render is good.
                But if I now hit the render again, Maya crashes.
                Thanks,
                Jason
                always curious...
                  Yes, exactly. I can confirm that the option is enabled and after 3-4 renders on 2 different machines here there wasn't any crashes. Let me try once again.
                    Hi Tashko, I just sent the .dmp file to you via email. Please let me know what you find.
                    always curious...
                      Thanks for the dump, we have successfully reproduced the problem. We'll inform you when we have some progress on fixing the issue.
                      V-Ray for Maya dev team lead
                        This will be fixed in tomorrow's nightly build. The fix will also be included in our next release.
                          That's great! Thanks Mihail. I don't have to worry about converting those ptex to uv maps then.
                          always curious...
