I'm having a weird problem when I have two clippers on two separate pieces of geometry that are overlapping. I'm trying to re-create the pencil from the docs and I can't seem to make it work unless there is a slight offset on the meshes which obviously leaves an edge. Both clippers have the other clipper and geometry excluded from each other.
This is what is does:
I've offset the two meshes a bit, which works ok for this, but I can see that as being an issue on something that needs to be more precise:
