OLS 4.3.1 does not work with CentOS 7.3.
  • OLS 4.3.1 does not work with CentOS 7.3.
    OLS 4.3.1 does not work with CentOS 7.3 ?
    FirewallD is off, vrlservice is running.
    However, localhost:30304 can not be accessed.
    What is wrong?
    OakCorp Japan - Yuji Yamauchi
    oakcorp.net
    v-ray.jp
    Could you please make sure you install the license server as a sudo user rather than with the root? Installing V-Ray license server with the root user will result in non working service.
    Nikolay Kirov
    support@chaosgroup.com
    Chaos Group
      We recommend our Linux users to install V-Ray OLS with the local user. So please re-install (uninstall and install) the V-Ray Online license server with your local user, instead of "root" user.
      Please uninstall V-Ray OLS from here: /usr/ChaosGroup/VRLService/OLS/uninstall
      Then make sure that the below mentioned folder is removed/deleted after the un-installation process:
      Let us know if the above suggestion helped you.
      Stefan Isakov
      Contact Support
      Chaos Group
        thank you for the advice.
        It worked with installation with sudo user.
        It may be better to note the document
        oakcorp.net
        v-ray.jp
          I'll add a note about that into our Documentation project task-list.
          Thanks for your feedback.
            Additional questions
            If you access the OLS remotely (EX: http://machine:30304/), the important operations are required for local operation.
            Is there a way to remotely perform important operations?
            only via VNC?
            oakcorp.net
            v-ray.jp
