VRayVolumeGrid not visible in the viewport.
  • VRayVolumeGrid not visible in the viewport.
    I cannot seem to get VRayVolumeGrid to be visable in the viewport using VRay 3.5. Nothing at all is visable. Even after creating the empty grid from the shelf, I cannot see the empty bounding box.
    If a vdb is loaded into the grid it renders, but doesnt affect the viewport issue. It makes it quite difficult to work with.
    I'm running OSX, tested Maya 2017 and 2016.5 both using VRay 3.5 and nothing is visable.
    I tested VRay 3.4 in maya 2016 and it works fine.
    Thanks,
    David.
    www.lunaranimation.com
    Seems like a bug. You're probably using the "Core Strict" openGL profile in your display settings. Until we fix it, you could try switching to "Core Compatibility". You can try changing the setting in Maya's settings and preferences > Display like in the attached image:
    Alex Yolov
    Product Manager
    V-Ray for Maya, Chaos Player
    www.chaos.com
