Vray gpu and cpu rendering supposed look the same?
  • Vray gpu and cpu rendering supposed look the same?
    Hello All
    Should gpu rendering and cpu rendering look the same? my gpu rendering is over saturated compared to the cpu version
    thanks in advance
    matt
    They are two different engines are results are not expected to render 1:1. Still, the difference that you see can be a bug. Do you have a sample scene that illustrates the problem, so we can check here if it is expected or not ?
    Best,
    Blago.
    V-Ray fan.
    Looking busy around GPUs ...
    RTX ON
      hello,
      Please find attached a test scene, the issue is with the stochastic material
      please see attached file
      chaosgroup.zip
      thanks
      matt
        Originally posted by matthew999 View Post
        hello,
        [ATTACH]37609[/ATTACH]
        thanks
        matt
        Thanks a lot for the scene!
        The reason for the differences on the stochastic flakes shader seems to be cause by the additive mode of the top-most blend material (this one). It most likely a bug and I have logged that.
        Best,
        Blago.
        V-Ray fan.
        RTX ON
          ah cool thanks for that
          cheers
          matt
