Bucket difference when using lightcache?
  • Bucket difference when using lightcache?
    Hi
    i've been having some issues with bucket difference. at first i thought restart vrayslaves or computers would do the trick. that used to be the solution way back. But its still there when i start up again and render the scene. However if i change to BF/BF only there is no problem, so the problem is in the lightcache?
    i've attached a few screenshots of the renderings and my lightcache setup
    i'm using a nightly build v. 3.57.01
    It's probably due to the adaptive lights, but it really shouldn't be happening. Is it possible to post your scene or send it to me at vlado@chaosgroup.com ? Also, which particular nightly build are you using?
      Any solutions on that?
      I think this is not a problem with 3.5 features or nightly builds because on older version sometimes I also got this problem.
      In my cases also the irradiance map has this issues.
      When i have this problems, a trick is to precalculate LC or IR on one machine and use this caches for the DR nodes.
        I can't really say without a scene, unfortunately.
          It is actually pretty hard to replicate.
          And also i do not have this issue very often.
          I think in my case there is a problem with the computers because some of them are very old.
