volumegrid bug vray 3.5
  • volumegrid bug vray 3.5
    Hi Guys,
    Working with a houdini smoke sim and I am trying to render it the way I used to do it in vray using the vrayVolumeGrid. But, in vray 3.5, when I disable the "temperature" channel vray doesnt render the smoke either.
    I installed an older version of Vray and it worked again.
    What to do?
    vray 3.5 with maya 2016
    Thanks!
    Ah just found out that if I enable the temperature again and lower the fire opacity to 0 it gives the correct result.
      Hey, can you attach screenshot of how the render looks with temperature enabled and what are your fire, smoke color and smoke opacity settings?
      Where do you disable the Temperature channel - is it in the Fire rollout?
      Cheers!
        Hi Svetlin,
        Attatched a screenshot.
        Temperature is enabled here and the preview shows the "smoke".
        The second screenshot is what it is supposed to look like. This is with temperature enabled but opacity at 0. In older versions I did not need to do this.
        Smoke opacity is set to simplesmoke, and color to constant white.
          Hey,
          I meant the settings of the volume grid itself
          Thanks!
            Ow sorry. Here ya go:
            I use the Houdini fire/smoke preset and change very little except for disable fire.
              Sweet, got it! Thanks very much!
