V-Ray Baking will crash on Windows Maya 2017 update 3 + V-Ray 3.52.02
  • V-Ray Baking will crash on Windows Maya 2017 update 3 + V-Ray 3.52.02
    At Windows Maya 2017 update 3 + V-Ray 3.52.02,
    V-Ray Baking will crash.
    Please try the following procedure.
    - Load the attached scene and reset the path of the texture assigned to the Cube to the included test.jpg.
    - Save as scene. (xxx.ma)
    - Restart Maya 2017. (important)
    - Load xxx.ma and assign single V-Ray bake option.
    - Lighting/Shading >> Bake with V-Ray..., It will crash.
    There are cases where it does not crash, but when you do it in Maya after the start you will often crash.
    tested scene
    test.zip
    OakCorp Japan - Yuji Yamauchi
    oakcorp.net
    v-ray.jp
    we are aware of that issue. It is fixed and will be available in the next release.
    Ivan Shaykov
    chaos.com
      thanks... we have tgat bug too..
        Ok.
        Expecting to fix.
        oakcorp.net
        v-ray.jp
          any news here... we get a lot of crashes here...
            This should be fixed in the latest nightly builds since a few weeks now.
              thanks will try...
                It is not fixed in V-RayMaya 3.52.03
                What is going on?
                FIx reflected in stable build?
                oakcorp.net
                v-ray.jp
                  The fix is applied for the 3.60.01 stable builds. You can download and use them instead of the 3.52.03 build.
                  Ivan Shaykov
                  chaos.com
                    Thank you for information.
                    I will try the 3.6 branch.
                    oakcorp.net
                    v-ray.jp
