Maya Crash
    Thanks, I'll test them and get back to you with more details.
    Ivan Shaykov
    chaos.com
      Is the switch value in the SwitchMtl mapped or animated (if you're trying to render more than one frame)? Sharing your render settings (as preset maybe) could also be very helpful.
      Ivan Shaykov
      chaos.com
        Hi Ivan
        Sorry for the delay.
        The switch value isn't animated or mapped, from checking.
        I've PM the render settings.
        Cheers
          Ok, thanks for PM-ing the render settings. I'll apply them and make some more tests and hopefully it reproduces the issue.
          Ivan Shaykov
          chaos.com
            still no success on reproducing it here. Is it possible to share the scene stripped without the CAD geometry or anything that can't be shared? Also could you please try assigning the scanned materials directly to the geometry without using the switch material.
            Ivan Shaykov
            chaos.com
            • #21
              Hi Ivan
              The scanned materials applied directly fixed the issue.
              Not sure what I can share, without stripping out pretty much everything, sorry.
              Cheers
              • #22
                Ok, another idea is to share the scene without any geometry and maps (even if the scene remains completely empty). We can try adding our geometry while using your setup (especially for the switchMtl) and try reproducing it on your scene. Unfortunately sharing the render settings only didn't help.
                Ivan Shaykov
                chaos.com
