White lines on vector displacement - PhoenixFD OceanTexture
  • White lines on vector displacement - PhoenixFD OceanTexture
    Hello I'm having problems when trying to use the Ocean texture from PhoneixFD in a polygonal plane (Maya 2016 SP6, V-Ray 3.5 Trial).
    I am sending the sequence of images and some screens attached!
    Thanks a lot for the help
    Hello,
    This is a known issue and we're working on it.
    If you are after a flat ocean surface you can use the Phoenix Simulator in Pure Ocean mode - this way you won't have to simulate and you will get correct results.
    As for the issue you are having I will update the thread when we have a fix for that.
    Thank you,
    Georgi Zhekov
    Phoenix Product Manager
    Chaos
      Originally posted by georgi.zhekov View Post
      Hello,
      Thank you,
      Georgi, thanks a lot for the help!
      I downloaded the Phoenix FD (Trial) and used the Simulator in Pure Ocean worked well! But the render farm I was using did not have PhoenixFD support.
      So I tried using the Water Map | VRayWater Works like a charm! It renders very fast in Full HD and works on all renderers farms that I had access to.
      Thank you for your help
