V-Ray" does not provide a sequence render procedure
  • V-Ray" does not provide a sequence render procedure
    if i try to use the new render sequence in maya 2017 i get this error message...
    is this a missing feature or is there a workaround...?
    https://linktr.ee/cg_oglu
    Ryzen 5950, Geforce 3060, 128GB ram
    The render sequence is just a gimped version of the standard batch renderer, there's no reason to use it with V-ray. It's made for renders like the free version of MR and Arnold that don't provide batch rendering.
      for me there is a reason... i like to store the image in the maya render view... if its not supported im fine with that... i find a other way...
        This feature is not currently supported.
        V-Ray for Maya dev team lead
          thanks... its now in the nightlies...
          :: Implement Maya 2017 render sequence
            Yes, it's already in the nightlies. It would be appreciated if you could give it a try and let us know if it works as expected.
            Alex Yolov
            Product Manager
            V-Ray for Maya, Chaos Player
            www.chaos.com
              does work fine... thanks...
              also "add to renderview" does work... great...
