I have a scene with a ton of Render Layers using Maya 2017's render setup. In the file name prefix in the render settings, I used to use "<Scene>/<Scene>_<Layer>" however with update4 in Maya it doesn't recognize the legacy "<Layer>" token. The Maya manual says to use the token "<RenderLayer>", however VRay doesn't seem to recognize this at all. I'm stuck at the moment, and it basically looks like Vray doesn't recongize Maya's new Render Setup system. What's going on??
"RenderLayer" render token for File Name Prefix not recognized
Just switched to Legacy Render Layers. Now the render layers I created in render setup shows up, and it appears to show me the passes I've made. However, when I actually batch render, it just renders into oblivion. There's no actual output file made, either in the TMP folder, or in the folder I designated. Although all my cores are being used, literally no file comes out.
*edit - seems to work fine if I render to the Vray Buffer Window. Seems to be a problem with the batch renderer. Although, when I updated to the nightly, it changed some of my render settings.Last edited by ANDREW_LEUNG; 07-07-2017, 11:11 AM.
Originally posted by ANDREW_LEUNG View Post*edit - seems to work fine if I render to the Vray Buffer Window. Seems to be a problem with the batch renderer. Although, when I updated to the nightly, it changed some of my render settings.Ivan Shaykov
chaos.com
