VRay: Could not load the Bifrost module!
  • VRay: Could not load the Bifrost module!
    I just gave the 3.6 stable 27650 build a spin in Maya 2017 Update 4. I see this in my render log:
    >>> Error: line 1: VRay: Could not load the Bifrost module! You will not be able to render Bifrost as isosurface or metaball. The error message is:[loadLib] dlopen failed: //FILESERVER/pipeline/bin/vray/builds/170831_vray_v3.60.01-stable-b27650-maya2017_linux64/maya_vray/bin/libvraybifrost.so: undefined symbol: _ZN12VRayBoost1616system16generic_categoryEv
    Do you know what could be causing this issue?
    Best Regards,
    Fredrik
    on what OS do you get this error (judging from the log it might be Linux)? Are you running V-Ray from a zip install or the regular installation?
    "Error: line 1: VRay: Could not load the Bifrost module! You will not be able to render Bifrost as isosurface or metaball" You should be getting this error only on OSX systems.
    Ivan Shaykov
    chaos.com
      Yes, Linux (CentOS 7). It's a zip install of V-Ray.
      Best Regards,
      Fredrik
        It looks like this is a known issue. I'll bump it's priority and we let you know when there is some new information about this.
        Thank you for your feedback.
        Ivan Shaykov
        chaos.com
          Ok, thanks Ivan.
          Best Regards,
          Fredrik
            Just checking back in... do you think this will get fixed for V-Ray 3.6?
            Best Regards,
            Fredrik
              which V-Ray version are you using 3.60.xx?
              Ivan Shaykov
              chaos.com
                Hi, we're on 3.60.04 official release for Maya 2018.3.
                Best Regards,
                Fredrik
